Old 17-11-2005, 01:06 PM   #1 (permalink)
Default urgent help
My friend has a p3 1ghz config. He is facing some weird problems offlate. Before windows loads up, he is getting the following messages on the dos screen. "checksum error" " Warning!your CPU speed has been changed.Set the speed,save and exit." He continues booting the system hitting F1 nevertheless and nothing seems to add up. Any suggestions are welcomed.
/legolos
legolas is offline
Old 17-11-2005, 01:26 PM   #2 (permalink)
Motherboard battery is dead. Put a new battery and then configure the settings in the BIOS. The error won't come again.
Compaq Presario Notebook, AMD Mobile Sempron 3000+ (1.8 GHz), ATI Mobility Radeon Xpress (PCIe) 200M 128MB Graphics, 768 MB DDR 333 MHz RAM, 40 GB HDD, DVD+CDRW Combo, 15".....
krish is offline
Old 17-11-2005, 01:41 PM   #3 (permalink)
choudang's Avatar
i heard the same problem....... its the time to change the Battery.
there is a another prob i have seen ... battery is ok.. but still the customer have to play F1 to continue.. i'm sure that EPROM is gone.. how do i repair that .. any sugg
choudang is offline
Old 17-11-2005, 02:04 PM   #4 (permalink)
As he said that he has got a PIII 1 GHz so it must be quite old now. And so the more chances are that the battery is dead. And anyway that's the cheaper solution to diagnose and try.
krish is offline
- by gforz
- by soumya
