Old 17-11-2005, 02:09 AM   #1 (permalink)
Default W2K SP2
I recently upgraded to W2K. Everything's fine. Then I got SP2 n things got weird. Like this:
I shutdown and switch power off (switchboard).
I switch power on (from switchboard) and comp starts automatically without me touching the "power on" button on cpu.
What's happening?
naru is offline
Old 17-11-2005, 01:47 PM   #2 (permalink)
choudang's Avatar
are you using a ATX PSU? if so oit should not be happend. do you have a switch on your PSU? try with that also
choudang is offline
Old 17-11-2005, 01:50 PM   #3 (permalink)
puja399's Avatar
Maybe the magnetic switch of ur cabinet is faulty, u need to repair/ change it.
puja399 is offline
Old 17-11-2005, 06:02 PM   #4 (permalink)
yeah
the problem lies with the power button
i have the same problem
Geniusboy is offline
Old 18-11-2005, 12:41 AM   #5 (permalink)
Whats a PSU?
I have a HP Brio PC 600 Mhz P3 pentinum
64 mb ram
matrox mga g200 graphics
8.4 gb hdd
Faced the same problem when I tried WinXP
Is it something to do with 64-bit and 128-bit structure?
naru is offline
Old 18-11-2005, 04:48 PM   #6 (permalink)
vignesh's Avatar
Maybe you pressed it to hard..
vignesh is offline
- by gforz
- by soumya
