Old 16-11-2005, 09:23 PM   #1 (permalink)
choudang's Avatar
Default KBPS fussion
i have a fussion about kbps
i know that kbps stands for two ab@n kilobytes per second and kilobits per second.. but my fussion is started suddenly. let us asume that i'm having a internet connection @256 kbps..... what will be the output? it will be 256 kilobits or kilobytes per second?
help me out guys....
PS: i think it will be 256 kilobits... if so... can anyone tell me why it is not kilobytes.. whats the diff?
choudang is offline
Old 16-11-2005, 09:27 PM   #2 (permalink)
Biplav's Avatar
a 256 kbps connection means u can transfer data at the rate of 256 kilo bits per second i.e 32Kilo bytes per second.
"Try again, fail again, fail better" - Samuel Beckett
Biplav is offline
Old 16-11-2005, 10:41 PM   #3 (permalink)
desertwind's Avatar
kbps = kilo bits per second
kBps = kilo bytes per second
Sometime you'll think you understand everything
...Then you'll regain consciousness
desertwind is offline
- by gforz
- by soumya
