Old 16-11-2005, 06:33 PM   #1 (permalink)
Default dual vision????????????????????
hi!!i have a problem. I have win xp sp2 in my system with a peculiar thing. a week after installing it, in the right side of the desktop an image of the folders in the leftside is seen.why is this happening???????????
alaap_anujan is offline
Old 16-11-2005, 07:55 PM   #2 (permalink)
Laptoping
Sourabh's Avatar
What do you mean to say? Upload the screenshot of the desktop to make some sense. Press the PrintScreen key on your keyboard while you are at your desktop, and then open MS paint and paste the image. Save the file and upload it at www.imageshack.us
Sourabh is offline
Old 16-11-2005, 08:51 PM   #3 (permalink)
could be ur gfx card or ur VGA drivers
try changin the resolution and colour depth of ur pc and see if anything changes
also, if ur monitor is right next to a UPS, some mobile network enhancer or booster or something, or something like that, try changin the position and see if it gets btr
ishaan is offline
- by gforz
- by soumya
