Old 15-11-2005, 02:51 PM   #1 (permalink)
linardni's Avatar
Default Bluish Monitor-Help
The monitor shows a blue colour. Even upon reinstallation teh problem persists. The DOS text are shown as blue coloured font upon black background as default. Even in windows everything is upon a blue screen. Reinstallation of dispaly driver didnt help. Degauss failed to bring any effect. Plz help.
linardni is offline
Old 15-11-2005, 09:00 PM   #2 (permalink)
puja399's Avatar
Take it to the servicing people.
puja399 is offline
Old 15-11-2005, 09:13 PM   #3 (permalink)
siriusb's Avatar
I'll bet on a loose cable or unclean contact in the monitor socket. Just make sure that the contacts are not the culprit before you take that crt to a service station.
http://myxp.blogspot.com
Winchester 3200+ @2,500MHz
siriusb is offline
Old 15-11-2005, 09:17 PM   #4 (permalink)
sujithtom's Avatar
I think its the moniter prob. I had similar experiences but the colour was green and they said it was due to humidity. It sometimes worked when i slapped the moniter
http://geeksbay.monzilla.info - My Tech Blog :)
sujithtom is offline
Old 16-11-2005, 02:49 PM   #5 (permalink)
linardni's Avatar
lemme check the cable connexion & contact in the monitor socket b4 taking to the service station.
linardni is offline
Old 24-11-2005, 11:02 AM   #6 (permalink)
linardni's Avatar
ya...i corrected the problem.....one of the contact pins of teh monitor was bent and was out of contact. i straightened it and inserted in the port....the problem vanished.
thanx buddies for all ur clues...
linardni is offline
- by gforz
