Old 10-10-2004, 02:21 AM   #1 (permalink)
Default Is this available
Is This available in india
AMD FX-51 / AMD Athlon64 3800+ ( Socket 939 / 940 )
and which hi-end model is available in india
please any body can tell me peice also
savithk is offline
Old 10-10-2004, 08:43 AM   #2 (permalink)
Hi savithk,
Yes, both are available in india.
AMD FX-51 costs ~ 41000
AMD Athlon64 3800+ is Rs. ~ 32400 to 29000
And yea, did I mention a compatible motherboard will set you back by atleast 20,000?
Regards,
Yes, I\'m back. Not 24x7 yet, but pretty soon.
Please be a bit considerate (don\'t bombard me with PMs and all) as I need to some time to Synchronize my brain with the forum.
Any inconvenience caused is regretted.
[deXter] is offline
Old 10-10-2004, 12:14 PM   #3 (permalink)
darklord's Avatar
Originally Posted by [deXter
]Hi savithk,
Regards,
And yea, did I mention a compatible motherboard will set you back by atleast 20,000? ---> WHo told you that?
For AMD Athlon 64 3800+ [Socket 939] the board is Asus A8V Deluxe and is available for 11,000-12,000/-
As for the AMD Athlon 64FX 51[Socket 940] it has two boards, Asus SK8N,SK8V both in the range of 15,000/-
There are boards from Gigabyte too,for the FX based on Nforce 3 150.
darklord is offline
Old 10-10-2004, 12:52 PM   #4 (permalink)
enoonmai's Avatar
You know, I still don't see the point of a 64-bit processor sitting there, unexploited, until good 64-bit apps and games come out. Wouldn't it better to just hold out on the A64 until XP 64b edt. comes out?
Playing FEAR XP/LSW2
enoonmai is offline
Old 10-10-2004, 01:22 PM   #5 (permalink)
Default savithk
Hi savith kumar from Ahmedabad . iam planing to buy new AMD PC for 3D animation ( MAYA , 3DMAX ). i really want to buy AMD FX-51 / AMD Athlon64 3800+ ( Socket 939 / 940 ) . but my AMD reseller told me this model is not available in Ahmedabad so he offer me AMD Opteron Processor with Registered ECC RAM . this is very expensive for me . what do u thing about AMD Opteron .
waiting for reply
savithk is offline
Old 10-10-2004, 01:24 PM   #6 (permalink)
Default which is the best
which is the best High-Performance Computing
AMD Opteron Processor or AMD Athlon 64 FX Processor
savithk is offline
Old 14-10-2004, 10:36 PM   #7 (permalink)
Hi , the only difference between an amd opteron and amd athlon64 is the same as the difference between athlon xp and athlon mp , multiprocessor support and non multi processor support .So i guess you got my point here ... if are using 1 way opteron then no use .. if you are using either 2 way, 4 way or even 8 way boards based on SLI , VIA or Nvidia solutions it would be gr8, but remember the price and performance comparison is not that gr8.
AMD64 2800+ 1GB ECC DDR 400 ,MSI K8T800 Asus Geforce FX 5200 128 MB, 120 GB Barracuda,16X DVD RW,Samsung 16x DVD,Samsung Wireless ,Creative AUDIGY2 ZS 7.1 with Creative Inspire 7.1/1800+AXP 512MB ECC DDR400 .40GB BLACK
indro is offline
