15-11-2005, 11:28 AM
Cool as a CUCUMBAR ! ! !
Open With ! ! !
how do u clear some unwanted software names assossiated open with ???
ie r-clicking on any file & on pointing 2 open with ... i get lot of options ...
15-11-2005, 12:46 PM
http://myxp.blogspot.com
Winchester 3200+ @2,500MHz
15-11-2005, 12:56 PM
but if i open a file with wrong applictn nd den how can i make it to open with da correct1:
actually i downloaded a song...it was interrupted while downloading...so to continue downloadin i opened da incomplete file with da downlaoder....den after downlaoding also it remains to b a downloader file only not a winamp file!!!!
BYE!!
------MOJOJOJO------
\"I\'ve Got A Great Ambition To Die Of Exhaustion Rather Than Boredom.\"
\"Where Would You Go When You Can\'t Forget The Past And You Don\'t Know The Future.\"
15-11-2005, 02:18 PM
Press Shift and right click on the file, then select "Open With..." option. Select correct application (in your case, Winamp) and place a check under the option "Always use the selected application to open this kind of file" and press OK...
This will work in Win 9x. In Win2k/XP, it will work if you have administrative priviledges...
Arun
15-11-2005, 02:19 PM
If u are not using xp, then to make the open with dialog appear again, hold the shift key while rightclicking the file. Select the app you want to open the file.
In XP, you will have either the "open with" or Open entry always.
You could also goto "Control panel->folder options->File types" to change the default app and icon.
Download managers will change the extension of the file as soon as it completes the download and verifies that no part is corrupted. If u are sure that the file is downloaded completely, then simply change the extension of the file to mp3 or whatever music format you downloaded.
15-11-2005, 04:52 PM
tip was 4 w2k ...
whot at xp ???
... W H O T ...
15-11-2005, 04:54 PM
as i have 2 acroat reader entries ...
... W H O T ...
15-11-2005, 05:27 PM
The tip submitted by siriusb should work with WinXP also...
Arun
PS: Always backup your registry before trying something you are not sure of.
15-11-2005, 06:46 PM
Common registry editing programs like RegSupreme too can do it..
http://www.macecraft.com/
It has a "Open with menu" tab where all applications are listed, you just choose what you want and remove them.
alibi
-Metallica
Search this Thread |
