Old 15-11-2005, 11:26 AM   #1 (permalink)
Laptoping
Sourabh's Avatar
Default Daemon Tools v4, Now with Adware!
Dear DT-Community,
today, we release the new V4.00.
As we already heard from our customers, it fixes indeed
most or even all blacklists - however, it is STILL a SCSI-Emulator,
therefore it's still necessary to remove present IDE-Drives!
As nearly all protections now block ALL SCSI-Drives, no matter
if REAL or VIRTUAL, you need to DISABLE your ide-drives!
This version is more or less only a "next step", it does NOT
contain an IDE-Jammer atm. However, we are working on it and
will hopefully have it ready soon. So be warned - do NOT complain
about the "lack" of the IDE-Jammer-Device. We release it now,
as is. It fullfilles its job as long as no IDE is present in
System or you otherwise block that IDE-nodes. After all it's
STILL free!
Another important change is the integration of ADWARE.
Yes, we need that revenues. However, we decided to let
YOU choose to run it with ADWARE and support us - or simple
turn it OFF in installation-process and run it same way
as former versions - without ADWARE. By default, it is turned
ON - to not install that ADWARE, please UNCHECK at installation
"DAEMON TOOLS SEARCHBAR" (or you can remove it anytime later when
you wish via "Control Panel"-> "Add/Remove programs")
We leave that decision to you, so please don't blame us that we did
it that way. It was a compromise to continue the free support -
we would much appreciate it if you install that ADWARE-stuff. We set-
up a special forum so please post in THAT forum only about questions,
concerns or anything else that is related to that ADWARE. The forum's
name is "DAEMON Tools Searchbar".
view the changelog here
for the download and other info check out Daemon-tools
Sourabh is offline
Old 15-11-2005, 02:53 PM   #2 (permalink)
The adware can be not installed. It is still an option during an install process. The one thing which worries me is the disabling of drives. Lets see...testing it now..
AMD 64 3500+ Venice
DFI Lan Party Ultra-D
XFX 7900GT 256 MB Card
icecoolz is offline
Old 17-11-2005, 06:47 PM   #3 (permalink)
GameAddict's Avatar
Let us know guys, how good is DT in reducing the hassle of mounting images. (SF, SD etc.)
GA
GameAddict is offline
Old 18-11-2005, 03:13 PM   #4 (permalink)
bala4digit's Avatar
its da best nothin can beat it!!!!!!!!!
BYE!!!
-MOJOJOJO-
\"I\'ve Got A Great Ambition To Die Of Exhaustion Rather Than Boredom.\"
\"Where Would You Go When You Can\'t Forget The Past And You Don\'t Know The Future.\"
bala4digit is offline
Old 18-11-2005, 03:19 PM   #5 (permalink)
Well so far, most of the games I have thrown at it is working. Serious Sam 2 does not need antiblaxx, Quake 4 works like a charm as long as you block it from accessing the internet, have to try starforce ... lets see.
AMD 64 3500+ Venice
icecoolz is offline
