Old 09-10-2004, 11:30 PM   #1 (permalink)
Default Help unstalling .Net Framework SDK Beta
Help !
I made the mistake ages back of installing Microsoft .Net Framework SDK Beta v1.0.2204.
Since then, it doesn't run 'coz it was a Beta. Plus I can't upgrade it / install a fresh .Net Framework Redistributable / SDK since the fresh installer program detects the presence of this earlier Beta. The Uninstall Icon is disabled when I try to remove the Beta from 'Add/Remove Programs'.
There are programs I need to run that work only on .Net Framework, and I need to install it pronto.
I even tried renaming the folder in Windows directory, but it still senses the Beta. Then I got fed up and deleted the folders containing the framework. Still no use. Then I even went through the entire registry and removed everything that mentioned ".net" !
Still keeps detecting the beta.
Can anyone help me please ?
Regards,
Nilay
nilaymehta is offline
Old 10-10-2004, 12:18 AM   #2 (permalink)
QA Juggler
saROMan's Avatar
ouch.... .NEt is really a pane in the a** , wel u wud have suggested all the things u hav just mentioned ...try total uninstaller ...to uninstall...or else...same old way format c:
8-) सारोमान :!: :!: :!:
saROMan is offline
Old 11-10-2004, 02:42 PM   #3 (permalink)
First of all, try to uninstall all existing versions of the sdk. After you
did that, open your registry and delete the following (if they exist)
HKEY_LOCAL_MACHINE\Software\Microsoft\.NETFramewor k
HKEY_LOCAL_MACHINE\Software\Microsoft\NET Framework Setup
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\Curr entVersion\Uninstall
\{C9913503-1500-4454-94CD-365ADC1BB9B9}
Restart, and install the Framework.
( PS: Btw, I also posted the same reply at the 'other' place that you posted too He and me are the same persons, only thing is I was called by that name even before I known as dexter.. That was my original nick- even before the net came to India )
Yes, I\'m back. Not 24x7 yet, but pretty soon.
Please be a bit considerate (don\'t bombard me with PMs and all) as I need to some time to Synchronize my brain with the forum.
Any inconvenience caused is regretted.
[deXter] is offline
- by gforz
