Old 14-11-2005, 05:17 PM   #1 (permalink)
Default DeFragmentation Vs Formating HDD
Dear Friends,
I wanted to know the diffrence between Defragmentation and formating the HDD.
Which one Enchances the efficency of HDD?
I am going to format my HDD, so whether i can perform, defragmentation after Formating? If yes then Will it enchance my HDD performance?
Plz help
Tnx in advance
Andyiz is offline
Old 14-11-2005, 06:52 PM   #2 (permalink)
godsownman's Avatar
I feel you are confused.
Defragementation
This means to de-fragment i.e. to collect all the fragments of a particular file and put them together so that it opens faster the next time.
But , you cannot constantly defragment the drive .
Format
This means to clear the harddisk of all its files ( DELETE all ) . This is done before you generally install the OS again.
I have seen many people who do this every 4-6 months.
I have never felt that the performance of the computer has improved after a defragment.
Hope this helps.
godsownman is offline
Old 15-11-2005, 12:13 AM   #3 (permalink)
Microsoft MVP
Vishal Gupta's Avatar
If u hv data and don't want to format the drive, then Defragmentation is the BEST option.
Otherwise I'll prefer formatting the drive in stead of defragmenting it...
And yes! U can defragment the drive after formatting and instaaling the OS or storing other DATA in it.
:arrow: http://www.AskVG.com/
Vishal Gupta is offline
Old 15-11-2005, 07:42 AM   #4 (permalink)
"Technologic"
Apollo's Avatar
Not really suggesting anything. Rather, I'm asking a question: Is it a rumour or confirmed fact that with formatting your HDD, you are reducing its life?
One great use of words is to hide our thoughts.
Apollo is offline
Old 15-11-2005, 08:20 AM   #5 (permalink)
ramprasad's Avatar
Hi,
Its true that Formatting reduces Life of HDD.
I defragment every 6 months, just to make my sys a little faster....
Regards,
Ramprasad
ramprasad is offline
Old 15-11-2005, 10:25 AM   #6 (permalink)
vignesh's Avatar
Defragmenting also increases your system speed.Its actually should be done atleast once a month.
vignesh is offline
Old 15-11-2005, 10:28 AM   #7 (permalink)
Defragmentation vs Formating.
The first one is similar to rearranging, tidying up all the stuff in your room. Result - Everything's more easily accessible.
The latter would be equivalent to taking all the stuff from your room and dumping it in a landfill. Result - empty room.
Or you could read tech definitions here -
http://en.wikipedia.org/wiki/Defragment
http://en.wikipedia.org/wiki/Disk_formatting
-Keith
Keith Sebastian is offline
- by gforz
