Old 13-11-2005, 02:12 PM   #1 (permalink)
Default how to make a CD write protected?????
hi,
i want to know how we can write protect a CD
dittualex is offline
Old 13-11-2005, 06:45 PM   #2 (permalink)
im assuming ur talkin about CD-Rs not CD-RWs. write protecting a CD-RW wont be advisable cuz then it jus becomes a CD-R.
it depends which software u use 2 burn cds. look around the software for an option called MULTISESSION and disable it.
ishaan is offline
Old 13-11-2005, 08:13 PM   #3 (permalink)
I think he means copy protected.Is it?
ra_sriniketan is offline
Old 14-11-2005, 06:27 AM   #4 (permalink)
Learner
Kniwor's Avatar
ya i think he is either talking about CD RW's or copy protecting...
I dont thhink u can write protect a CD as of now...because u can always erase it and write again...
Kniwor is offline
Old 14-11-2005, 02:03 PM   #5 (permalink)
choudang's Avatar
i think he is trying to make a CD which can not be copied by any means.... if i'm right, sorry to say that i don't remember the name of the software. you can make it a Write protected CD.
choudang is offline
Old 14-11-2005, 04:04 PM   #6 (permalink)
if he means copy protect he shoulda sed so...it has been discussed already in the forums jus search
@kniwor...y cant u write protect a cd? if u turn multisessioning off, then u cant rite on the CD nemore...and u cant erase stuff in cd-rs only rws
ishaan is offline
Old 14-11-2005, 04:30 PM   #7 (permalink)
champ_rock
champ_rock's Avatar
http://www.thinkdigit.com/forum/view...=write+protect
Registered Linux user number 400618
champ_rock is offline
Old 15-11-2005, 01:31 PM   #8 (permalink)
In Writing a Cd Completely. Then after writing you will use Privacy software (From the site www.gamecopyworld.com) is easy to protected them please send me your advantage to gta_2688@yahoo.co.in
singhai_2688 is offline
Old 15-11-2005, 05:04 PM   #9 (permalink)
are u talking about copyrighted CDs ?
mangemayur is offline
Old 15-11-2005, 05:48 PM   #10 (permalink)
choudang's Avatar
ok..... here is the new question:
i have a cd with some files... now... i want to make my CD protected ----
1. the CD can't be copied. by any means.. if some one trying to CD-CD burning or Image burning --- he will not successfull
2. if we are view the CD, it should be display blank..... but it will show the size prop correctly.
any idea, i do know that we can do it by some software, anyone gives me the names of that software.... money doen't matter.
choudang is offline
- by gforz
