13-11-2005, 02:03 PM
cost of dual side DVD writer
hi,
how much does it cost for a dual side DVD writer?????
13-11-2005, 08:11 PM
9437077259
I got a Sony Dual Layer DVD Writer last month and it costed me about 3800 bucks. As Sony DVD Writers are the best, they cost a bit more. You can have cheaper DVD Writers also, but reliability is the issue...
13-11-2005, 08:15 PM
Got SONY Dual Layer Writer(3,700).Working great.
13-11-2005, 09:24 PM
Learner
I am not aware of anything like "Dual Side Writer" so any writer should be able to write both sides...it is perfectly sensible...
14-11-2005, 01:01 AM
it is actually dual layer and not dual side writer, meaning it can write on dual layered 8.5 GB DVD-R DL and DVD+R DL discs.Unlike the earlier ones, which have had support for only single layered 4.7 GB DVDs.
14-11-2005, 06:05 AM
Learner
yeah i know and i own a DL DVD writer.... but not a dual sided....so this thread goes nowhere...
14-11-2005, 10:17 AM
which cities give dl dvd writers....4 3k iam cumin up there guys....plss tell me>??!!
BYE!!!
--------MOJOJOJO--------
\"I\'ve Got A Great Ambition To Die Of Exhaustion Rather Than Boredom.\"
\"Where Would You Go When You Can\'t Forget The Past And You Don\'t Know The Future.\"
14-11-2005, 12:50 PM
9437077259
I got it from Raipur at Rs.3800 and must be some what less now. For about dual side, I guess all writers can write dual side DVD's as we have to literally put the DVD up side down to write on the other side. I dont think there is any DVD writer that can write on both sides of the DVD at a go without taking out the DVD and putting it again up side down.
14-11-2005, 01:04 PM
bang bang!
I got Liteon 16X Dual layer for 3900 frm Pune in june 2005. The rates must have surely gone down till now.
14-11-2005, 02:39 PM
Got my sony dvd writer few days back for 2800/= from Lamington Road, Mumbai 8)
Shakespeare quote - reg ex style - /(bb|[^b]{2})/
14-11-2005, 04:12 PM
There is no such thing as dual side writer, only dual sided DVD's.
As for dual layer writers, all writers in the market are dual layer. So just decide on which brand you want based on your budget. Any writer you buy will support dual layer DVD's.
14-11-2005, 08:40 PM
Is it DL? Can u give me the deails of the shop?
17-11-2005, 11:53 AM
@ bala4digit its availiable in vashi also i think,U can also try at Lamington road, in Marine lines.
17-11-2005, 12:47 PM
damn I got a sumsang writer for 3800 bucks.
living in delhi
17-11-2005, 12:51 PM
i got mine benq dw1640 for 3.5K from Alun Systems, Nehru Place
Shwetanshu Srivastava
17-11-2005, 02:18 PM
ru sure? :roll:
tanks to all 4 da info!!!!!!!
BYE!!!!!!
-MOJOJOJO-
17-11-2005, 09:10 PM
dear its ALSUN SYSTEMS not alun system..............check ur spellings plz
Search this Thread |
