Old 13-11-2005, 02:01 PM   #1 (permalink)
Default the date lags
hi,
in my computer ,even if i change the time and dates,after few hours,it lags.wht is the reason?
dittualex is offline
Old 13-11-2005, 02:15 PM   #2 (permalink)
desertwind's Avatar
Time to replace your CMOS battery.
Sometime you'll think you understand everything
...Then you'll regain consciousness
desertwind is offline
Old 13-11-2005, 06:48 PM   #3 (permalink)
maybe auto update of time is on and it updates the time for the wrong time zone
remove the auto update option and see
double click on the time on ur desktop. in the window wich opens, go 2 the INTERNET TIME tab. and remove the option from there.
ishaan is offline
Old 13-11-2005, 07:13 PM   #4 (permalink)
"Technologic"
Apollo's Avatar
As desertwind stated, it does look like your CMOS battery needs to be replaced.
But sometimes, removing the CMOS battery, and then replacing it back again also seems to work to put the clock back on track.
Give it a try!
One great use of words is to hide our thoughts.
Apollo is offline
- by gforz
