hey
i jus got quake 4 n i wz super excited
but now whenever i play the game it works for sometime and either it hangs and i need 2 do a hard reboot or it just closes and returns to desktop
i play on the lowest settings with evrything like shadows,etc turned off
my specs meet the requirements perfectly and my gfx card is the ATI mobility radeon 9700
on the box on the supported chipsets it says ati radeon 9700 but not mobility...does that make a diff?
i looked on the net some ppl had d same prob so dey updated dere gfx card drivers n it wz ok...but there are no updates for mine...and there have been no patches or anything released by the co.
its not pirated, n im not using any NO-CDs or trainers or anything
i even put off the network, norton, microsoft anityspyware, etc...all useless processes
and i set the laptop to the maximum performance settings with lowest power management
my virtal memory is also good enuf -700mb+
and i got lottsa space on my HDD for swap files, etc
one thing though...i have installed it on D and windows is on C (if that makes any diff tho it shouldnt)
wat do i do???
