Old 09-10-2004, 10:17 AM   #1 (permalink)
Default My CD ROM Drive died :(
i accidently put DVD in CD ROM drive..now my CD ROM drive is not recognising any CD. i dont know wat has happend. any help??
Bother no one. If someone bothers you, ask him to stop. If he does not stop, destroy him.
Visit: http://bodybuilding.name/
diab0lic666 is offline
Old 09-10-2004, 10:38 AM   #2 (permalink)
da' Ťurntable ruleth
techno_funky's Avatar
no way putting a DVD in a cdrom wont at all ruin it
it wont just read the dvd it will keep spinning in the drive
methinks this is some other problem
try cleaning up the lens with those cd lens cleaner
if under warranty take it to your service center
cause i dont think the DVD u put in is the culpurit
| Dell Studio 15 | iPod Touch 16GB (Stolen) | iPod Video 5.5G 30GB | Sony Ericsson W910i |
| Sennheiser PX 100 | Sennheiser HD 202 |Creative EP630 | Altec Lansing ATP 3 |
techno_funky is offline
Old 11-10-2004, 02:16 PM   #3 (permalink)
How can i clean up my lens when its not recognising any Damn CD
what to do???tell meeeeeee
Old 12-10-2004, 04:04 PM   #4 (permalink)
King of my own Castle
freshseasons's Avatar
You put up DVD drive into the Cd rom drive means you either accidently put the DVD into Cd really or somewhere you had hope it will be read by Cd rom or may be the curiosity got the better of you !!!!!
Anyway if you have acces to the DVd Cd isnt Getting your Cd rom damaged the best reason to upgrae to the DVD rom .....Drive
freshseasons is online now
Old 12-10-2004, 04:17 PM   #5 (permalink)
ice
Dude, it DOES NOT NEED 2 REgocnise the cd cleaner, it just needs to spin it
ice
ice is offline
Old 12-10-2004, 04:24 PM   #6 (permalink)
i have a philips lens cleaner, which needs to be played in media player to clean the the head of drive. Do you know any new Idea to spin the CD in drive without playing it???
Old 13-10-2004, 10:12 AM   #7 (permalink)
Is your drive being detected in Windows at all?
Can you operate the drive in other OSes ?
Yes, I\'m back. Not 24x7 yet, but pretty soon.
Please be a bit considerate (don\'t bombard me with PMs and all) as I need to some time to Synchronize my brain with the forum.
Any inconvenience caused is regretted.
[deXter] is offline
Old 13-10-2004, 01:22 PM   #8 (permalink)
ofcourse it is being detected...i think the only option left is to open the drive physically.
Old 13-10-2004, 02:21 PM   #9 (permalink)
wait guys was the DVD put in with the cover or without...No seriously this is a possibility.
**** happens
pradeep_chauhan is offline
Old 14-10-2004, 06:11 AM   #10 (permalink)
haha....how do u think a DVD will fit with a DVD case/cover into a cd rom drive????
Nemesis is offline
Old 14-10-2004, 11:40 AM   #11 (permalink)
club_pranay's Avatar
if u have the technical hand..... u can try to open it up yourself.... clean it using an optical lense cleaner(the 1 used to clean your eye glasses)NEVER USE THINNER, or any orher Harsh solvents.
btw i never cleaned my cd rom with a lense cleaner disc.
Be not Thou far from me o Lord....o my strength....haste Thee to help me.
club_pranay is offline
Old 16-10-2004, 12:18 PM   #12 (permalink)
Geforce's Avatar
You can clean it using an audio CD cleaner. It doesn't need any media player or anything. It will play automatically. If that doesn't work
I have another solution ... You can have my ASUS 52xCDROM drive for just Rs500/- . I just went DVD.
AMD Athlon64 2800+, MSI K8N Neo3(NForce4), 1GB Kingston DDR400, MSI Geforce 7600GT PCIe, Viewsonic VA702b 17" LCD, Creative SB Live! 5.1, Logitech Z-5300 5.1 THX Speakers, Seagate 200GB SATA HDD
Geforce is offline
Old 16-10-2004, 10:52 PM   #13 (permalink)
i opened up the Drive. now its working alrite. lens shaft was stuck.
Old 17-10-2004, 03:26 AM   #14 (permalink)
Just cleaning wont do.
Your lens has got damaged physically somehow??
Dont go for repairs Buy a new drive
amitsaudy is offline
- by bhaskar
- by Deepaks
- by Anorion
