Old 11-11-2005, 02:08 PM   #1 (permalink)
Default About my System Perform
Hi,
i have P IV2.4Ghz,Intel845GVSR,256MD DDR,40 GB 7200Rpm,
But Now a days the System performance is too slow.even a single program not working wothout sherking.
i think the HAdrdisk is affected in Bad Clusters...How i removing that ?????
i am using Win98 Se.
Reg
mahe :roll:
thanks for viewing my question
mahesu_87 is offline
Old 11-11-2005, 04:07 PM   #2 (permalink)
144
144's Avatar
My Advise is:
Back Up your Important info
Format your Hard Disk, Install Windows XP Professional with SP 2, and all the latest Security Patches from Microsoft
Install a good Anti Virus Software ; Be Sure to Update it and to RUN a Full Scan just following installation and keep it updated regularly.
Install Spyware/Adware removal tools/software , update to the latest definition files and keep it updated regularly, run systemically periodic scans
Your hardware is good enough for Windows XP, Use it - While installing be sure use NTFS.
On a long enough timeline, the survival rate for everyone drops to zero
144 is offline
Old 11-11-2005, 05:34 PM   #3 (permalink)
SNIST Screamer !!
vijay_7287's Avatar
well if r sure that the hard disk is the prob then try using norton disk doctor if still prob persists
then u should change the OS ...
since u say tht u bought a new system i suggest changing the os would settele it !!
vijay_7287 is offline
- by gforz
