Originally Posted by ax3
or is my power supply faulty ???
many tell me ... how do i check it myself ???
its easy....just do it carefully...
the main power supply cable which is attached with the mobo.... uplugged it. there are 10*2 cables. the cables are .. upper row: [left to right]
red/red/white/black/black/black/green/black/blue/orange---here take a wire or a pin -- make U shape and connect the
black with
green [left to right] --- then turn on power .. if your PSU starts as usual -- your PSU is OK. note: unplugged all the power connector if you are not sure....
you can use m/b monitor software to check the voltage frq or you can do it from BIOS also.
