Originally Posted by reddick
@ Tech&ME
THX 4 ur reply.I wana tell u that I have disabled all schedule tasks...My cabinet n power buttons seem 2 b fine...I think it's an odd problem
Today i place d CPU in laid position not standing but in laying position such a way that d mobo facing towards roof...n i worked upto 2 hrs. n no shut-downs n no any other problem!!! I surprised to see this  Anyone tell me why is it so...Plz tell me d permanent method to fix this problem...THX FOR UR PATIENCE
Ok so this is a hardware problem. Something in the mobo is lying looose. Do the following :
Step 1 :Check your RAM, remove it clean it and then re-seat it. Also lock it properly.
Step 2: Remove the processor heatsink, clean it, and then put it back properly and remember do not forget to connect the heatsink fan to the fan connector header on your mobo.
Step 3: Remove the hdd, and then clean it with soft cloth, put back the molex cable properly.
Step 4: Do the same as in Step 3 for your other optical devices.
NOTE: If you feel, you can remove the mobo also from the cabinet and re-install it again after cleaning it.
IMPORTANT NOTE: Do the above steps only if you know what you are going to do. If you are not a professional or have no idea at all about assembleing parts then better call a professional to do it for you. If something goes wrong because you did not followed the instructions above or you made a mistake all by yourself, I shall not be held responsible if you fry your PC.
