Old 10-11-2005, 10:55 PM   #1 (permalink)
Default SQL Problem
Getting a message 'Credential retrieval error' whenever i give the user name(scott) and password(tiger) in SQL.Plz help.
ra_sriniketan is offline
Old 10-11-2005, 11:37 PM   #2 (permalink)
choudang's Avatar
when you get this msg... scott don't have too many credential, you have to give the credential from sysdba
For every action, there is an equal and opposite criticism.
choudang is offline
Old 11-11-2005, 12:28 AM   #3 (permalink)
Can u explain in details wat do i have to do?
Old 11-11-2005, 01:29 AM   #4 (permalink)
choudang's Avatar
try to login connect sys as sysdba password is either oracle or change_on_install, if you will successfull then log out and try to connect as scott/tiger.
if you are unable to login as sys also, check the services from net start. if not start the services.
PS
sys: grant all to scott.
choudang is offline
Old 11-11-2005, 07:10 PM   #5 (permalink)
ok
Old 12-11-2005, 12:38 AM   #6 (permalink)
Coming back to life ..
it_waaznt_me's Avatar
Or use
Username : system
Password: manager
And I wait without you ...
With or without you ..
Batty = Too Busy Now !!!
it_waaznt_me is offline
- by gforz
