Old 08-10-2004, 11:34 PM   #1 (permalink)
Default upgrade RAM ?
Hi Guys
What do you think is the performance boost one expects if he upgrades his RAM from 512 MB to 1GB all other parameters remaining the same.
OS= win XP or Linux
Processor = P4 2.4 HT
mobo ASUS P4P800-VM (Dual Channel)
**** happens
pradeep_chauhan is offline
Old 08-10-2004, 11:44 PM   #2 (permalink)
Ya if u use s/w as oracle 9i, or IBM WSAD, or use vedio or image animation & editing.
any way normaly it also boost but u'll find out when u'll be using this.
Music is like Sex, The more you get, the more you want.
demoninside is offline
Old 08-10-2004, 11:47 PM   #3 (permalink)
Hey i mainly use linux+VMware(Win2000) + Metrowerks(an Embeded s/w developing IDE)
I ask this as the upgrade (2*256MB) will cost Rs 6000/- and this will fill up all DIMM slots.
What is the curve of performance boost Vs RAM size where does it flat out
**** happens
Old 09-10-2004, 12:16 AM   #4 (permalink)
RAM = speed
More RAM more speed
All ur applications will boost up. Esp Video - Audio Editing.
Go in for 1GB
Ish Karo... Ishq karna Tumhara Paidaishi Haq Hai........
Magar Kyon Na Is Bar Watan Ki Mitti Ko Mashuka bana le!!!
:) http://www.aseemn.org
Aseem Nasnodkar is offline
Old 09-10-2004, 07:26 AM   #5 (permalink)
my point is why stop at 1GB why not 1.5GB ?
**** happens
Old 09-10-2004, 07:53 AM   #6 (permalink)
144
144's Avatar
having 1.5GB of RAM is like having Blue Gene/L at home not knowing how to utilize it.
In short, if u r not video/audio editor its of no use.
On a long enough timeline, the survival rate for everyone drops to zero
144 is offline
Old 09-10-2004, 09:49 AM   #7 (permalink)
gxsaurav
Posts: n/a
U will see only about 5% speed increse in Windows & low loding times in games, that all, not required till March 2005
Old 09-10-2004, 10:09 AM   #8 (permalink)
Yup that's why i like gx
coz the perfact answer.
Old 09-10-2004, 11:11 PM   #9 (permalink)
enoonmai's Avatar
Come on guys, he's using VMWare. He's bound to see a much much better performance when he's running it with extra memory. I'd say the difference in performance would be phenomenal. Its not just A/V and games and 3D/image design that benefit from memory. Complicated application development and VMWare saps your computer's resources like nothing else. I've used VMWare before, and it slowed my comp to a near grinding halt. I thought the HDD LED would never stop blinking. Performance boost vs. RAM capacity hits a plateau at around 2 gigs in your situation I guess. Of course, like they say, the more the better. But, the performance increase after two gigs wouldn't be much because the system pathways hit a bottleneck because of the CPU speed.
Playing FEAR XP/LSW2
enoonmai is offline
Old 09-10-2004, 11:40 PM   #10 (permalink)
ok guys
so based on your inputs i got 2*256MB DDR 400 Kingston RAM today and am running the system with !GB of ram, the S/W Si soft sandra gives a minor boost figure but the working in VMware is much smoother thanks a ton for the valuable inputs.
**** happens
Old 10-10-2004, 11:47 AM   #11 (permalink)
dis will help in running damn cool games also...
ishaan is offline
Old 10-10-2004, 05:21 PM   #12 (permalink)
tell me some game that i can test the performance on. i have only q3 demo. also how do you check FPS in Q3?
**** happens
Old 12-10-2004, 03:51 PM   #13 (permalink)
q3a is good. also, for really-cool-game-testing...splinter cellandora tommorow, vice city, doom 3.
to check ur fps, type this in da console:
\cg_drawFPS 1
ishaan is offline
- by gforz
