Well, As I see what you mostly listen to requires high bass and Logitech speakers are known for their thumpy and effective bass. So I would suggest you to go for Logitech speakers. See this page for more details ->
http://www.logitech.com/index.cfm/pr...categoryid=422 . I guess
Logitech® Z-5300e will be perfect for you as they come in your given price range.
Also Altec lansing speakers are damn good and affordable ( depends upon product and matter of opinion entirely
) . Check them out here ->
http://www.alteclansing.com/index_in...ountry_code=in
Here are two 5.1 speakers available in India from Altec lansing which might interest you :-
http://www.alteclansing.com/product_...ountry_code=in
^^ I am not sure about their prices though.
Also, your topic name is misleading as you ask suggestion for the best speakers money can buy there and then set a limit of 12k. Frankly speaking 12k is not a huge amount spent on speakers. If you actually want speakers which can rock the house you should go for
Logitech® Z-5500 Digital
