Originally Posted by ****
The CPU usage is showing ok. Here is the list of my startup showing...
SOUNDMAN SOUNDMAN.exe
NeroCheck
igfxtray
hkcmd
avgcc
gnotify
hpztsb10
hpcmpmgr
gpgs2wnd
jusched
regsvr32 /s mqrt
Microsoft Office
Adobe Gamma Loader
You can safely remove the following:
igfxtray, hkcmd - graphics display tray icons
jusched - Real Player Update Checker
Microsoft Office, Adobe Gamma Loader - Not needed IMHO
gpgs2wnd - is that hpgs2wnd? That is HP Share to web which you can also disable.
regsvr32 /s mqrt: Check
http://greatis.com/appdata/a/r/regsv...20mqrt.dll.htm to see if you need it (I doubt it)
So far, I see no instance of Virus/spyware to cause problem... Have you got drivers all properly installed? And is your XP patched up to date?
Arun
PS: You havent yet mentioned your Security software...
EDIT: Why do I get **** wrote when I use quote button?
