Old 10-11-2005, 08:31 AM   #1 (permalink)
AMD user for 9 yrs!!
rollcage's Avatar
Default Plz .. tell what is this scary msg ..??
My Config: Athlon64 2800+, Ram 768MB, running WinXP SP2
I did change my keyboard n mouse .. but i dont think that is the problem ..
rollcage is offline
Old 10-11-2005, 09:36 AM   #2 (permalink)
anomit's Avatar
There can be many causes for this error message: the first and foremost being corrupted graphics or sound card device drivers.
Post the technical information and if possible, even a snapshot of the BSOD.
Don\'t SYN me, I'll SYN you. :p
anomit is offline
Old 10-11-2005, 11:06 AM   #3 (permalink)
MVP in VC++
Did u confront with BSOD?
cvvikram is offline
Old 10-11-2005, 06:17 PM   #4 (permalink)
champ_rock
champ_rock's Avatar
now i think that ur winodws should run fine..
happened with me... dont know how...... then automatically reapired itself....
does itt trouble u anymore ??????
Registered Linux user number 400618
champ_rock is offline
Old 11-11-2005, 08:45 AM   #5 (permalink)
rollcage's Avatar
no problem after n before that ... everything works good ..
but can enyone explain .. what could be the cause for that to appear??
no BSOD
1. everthing is working fine..
2. thats the problem that i didnt click for technical information..
I guess i was busy takin the screenshot ... poor me
So, tell me where do I locate that log file
rollcage is offline
Old 11-11-2005, 10:00 AM   #6 (permalink)
Search for .dmp file in documents and settings folder
Education... has produced a vast population able to read but unable to distinguish what is worth reading
AGENT_SMITH is offline
Old 12-11-2005, 08:37 AM   #7 (permalink)
rollcage's Avatar
Its Not there .. infact no .dmp file in C:
Edit: typo
rollcage is offline
Old 12-11-2005, 08:50 AM   #8 (permalink)
champ_rock
champ_rock's Avatar
he says .dmp not bmp rollcage..............
Old 12-11-2005, 08:56 AM   #9 (permalink)
rollcage's Avatar
.. Its not there ..
Sorry for typo
rollcage is offline
Old 12-11-2005, 12:14 PM   #10 (permalink)
vignesh's Avatar
Does this show up when you comp starts ?
vignesh is offline
Old 12-11-2005, 09:34 PM   #11 (permalink)
just get over it
its an error msg from when ur pc last shutdown due to an error
it doesnt mean anything
as long as ur pc is working fine right now dont make a big deal out of it
No Mercy, No Limits.
theraven is offline
- by gforz
