Old 09-11-2005, 11:49 PM   #1 (permalink)
godsownman's Avatar
Default DVD to VCD
Hi,
I am downloading a movie using Bit Commet but its a DVD RIP , what I want to know is can I burn a VCD from it .
I do not have a DVD writer. I have absolutely no knowledge about DVD's as of yet , thats why I am asking.
Also it is split up in to 49 parts of 14MB each . How should I merge each part and then see it like a continuous movie.
Thank You .
Regards
godsownman is offline
Old 10-11-2005, 12:12 AM   #2 (permalink)
choudang's Avatar
ok...
1> about the converting... it already discussed. anyway use Xilisoft DVD Ripper to make it VCD, where u will find 74min/80min and mini VCD/DVD along with 2 ch sound with various encoder.
2> use any joiner to join all the parts. i think u can use NERO Vission Exp.
For every action, there is an equal and opposite criticism.
choudang is offline
Old 10-11-2005, 11:55 AM   #3 (permalink)
most probably, alongwith the 14 files, 1 of em will be a batch file and if u click on it, it will join up all the files
but im not sure...normally ppl do that depends if that guy has done it or not
DVD to VCD - u can see many guides here 2, if u dont wanna use the method warrior suggested -- http://www.doom9.net/
ishaan is offline
Old 10-11-2005, 12:51 PM   #4 (permalink)
what file extensions are those 14 parts ?
if they are rar then extracting the first one will extract them all
No Mercy, No Limits.
theraven is offline
- by gforz
