Old 09-11-2005, 05:57 PM   #1 (permalink)
9437077259
go4saket's Avatar
Default VCD Dat Files on a DVD???
Hello Friends!
Is it possible to make a DVD behave as a large VCD. What I mean is, if I write a few DAT files that is on a VCD to a DVD, following the process of making a VCD, will the DVD players recognize it and more importantly, is it possible. If not, how can I get my VCD's converted to DVD's?
Thankyou.
go4saket is offline
Old 09-11-2005, 08:27 PM   #2 (permalink)
Yes. Here's a guide.
http://www.videohelp.com/forum/userguides/159399.php
For the final step, use Nero > from create disc wizard select DVD-Video and put all the files in the red VIDEO_TS folder.
More guides -
http://www.digitalfaq.com/dvdguides/...d/vcdtodvd.htm
http://www.dvd-guides.com/content/view/57/59/
- Keith
Keith Sebastian is offline
Old 09-11-2005, 10:25 PM   #3 (permalink)
sachin_kothari's Avatar
To Convert VCD to DVD use NeroVision Express
sachin_kothari is online now
Old 10-11-2005, 01:41 AM   #4 (permalink)
choudang's Avatar
if you didn't convert the .dat files to DVD or if u want to make a Data DVD with .dat files... don't worry .. you can do it. i have a 4.7GB DVD where i have put all my fav .dat files and i can view it in my DVD, but u won't get the menu.
no idea abt making a large VCD, which will be burn into a DVD. i think no cuz VCD will closed at 700mb.
For every action, there is an equal and opposite criticism.
choudang is offline
- by gforz
