Old 09-11-2005, 09:46 AM   #1 (permalink)
Chillum Baba
a_medico's Avatar
Default Physical Protection of CDs/DVDs
i have these thousands of cds which are creating a big prob of storage. i dont think i will use them very frequently but still i dont want to loose them. how do i protect them?
1) the cd stands which are available are never enough
2) folders are good option but still i have noticed if kept for too long in a folder under little bit of pressure, cds tend to stick to the folder at the surface of contact..
how do you guys store large number of cds/dvds?
thanks
a_medico is offline
Old 09-11-2005, 11:39 AM   #2 (permalink)
sms_solver's Avatar
buy big hard disk and copy them to it (cd/dvd image)
[ॐ एसएमएस॰सोल्भर ॐ]
sms_solver is offline
Old 09-11-2005, 01:33 PM   #3 (permalink)
Learner
Kniwor's Avatar
if not using frequently.......
those 100 cd packs keep cd's well if sealed properly...also damn cheap..those plastic ones that come when u purchase 100 blank Moserbaer or any cd .....
Kniwor is offline
Old 10-11-2005, 06:20 PM   #4 (permalink)
champ_rock
champ_rock's Avatar
curerently using the manufacturers box...... its a good option if u dont have to take the m out frequently........
Registered Linux user number 400618
champ_rock is offline
Old 10-11-2005, 06:46 PM   #5 (permalink)
Traceur
zegulas's Avatar
Use the 100 cd box, will even work if its not MOSERBAER!!!
The ordinary ones will be more cheaper but far more efficient than any other local options. 8)
Parkour: A journey started by two & followed by many...
zegulas is offline
Old 10-11-2005, 09:08 PM   #6 (permalink)
Learner
Kniwor's Avatar
lol......now that's a technically sound statement....!!!!!
(just said moserbaer for the sake of it...)
Kniwor is offline
- by gforz
