Old 08-10-2004, 03:36 PM   #1 (permalink)
Default Suspected Malware Infestation
Am using WinXP Pro on P4 2.8 HT with 512 mbs ram.
Since the last over three weeks some problems have arisen which I presume are due to some Malware Infestation.
1) On typing msg118.dll in Google Tool Bar/Search I get message "ERROR While trying to retrieve http://www.google.com/Search? following error was encountered - ACCESS DENIED"
2) On running Symantec->Security Center->Security Check->Virus Detection->Start A message appears "Downloading ActiveX Controls." Immediately thereafter a further message appears "The activeX Controls failed to load."
Spubot S&D reports presence of VX2/h.ABetterInternet. No matter how many times I fix the Selected Problems on the next run the same shows up ad infinitum.
Scan with eScan, NOD32 & Housecall/Trendmicro report "No virus found."
However NOD32 reports the folowing errors :
a) cagefile.sys - error opening (access denied).
b) C;\WINDOWS\System32\msguard.dll - error opening (File locked)
Please help me resolve this ASAP
Nariman
Nariman is offline
Old 08-10-2004, 04:51 PM   #2 (permalink)
Coming back to life ..
it_waaznt_me's Avatar
Please post your HijackThis Logfile for better assesment of your problem.
And I wait without you ...
With or without you ..
Batty = Too Busy Now !!!
it_waaznt_me is offline
Old 08-10-2004, 04:53 PM   #3 (permalink)
And btw look at ABetterInternet Removal Guide.
Old 09-10-2004, 01:38 AM   #4 (permalink)
Originally Posted by Nariman
Hello.
Platform: Windows XP SP1 (WinNT 5.01.2600) <-- Install SP2
To proceed with your HijackThis log, Run HijackThis again and put a CheckMark next to these entries and Click on Fix Checked.
Please make sure that all Internet Explorer and Windows Explorer windows are closed.
O4 - HKCU\..\Run: [PopupJammer] C:\PROGRAM FILES\ADVANCED SEARCHBAR\JAMMER.EXE
Old 21-10-2004, 07:41 PM   #5 (permalink)
Hello.
Case solved. No problems now.
Whilst waiting for your response did some R&D. Took my HDD to my friends place and connected it with his computer. Searched for and deleted MSG118.DLL & MSGUARD.DLL. Brought the HDD home and connected to my computer. Ran Ad-Aware SE Personal, et al. No trace of spyware. Ran NAV2005. No virus found.
Searched for the two DLLs. No Trace. No trace in Registry of the four entries entries associated with the DLLs.
Can now search for msg118.dll in Google/Search Bar. Can also access Symantec on line Virus check.
This is for information.
Nariman
Nariman is offline
Old 23-10-2004, 04:03 PM   #6 (permalink)
Bewitched!
xenkatesh's Avatar
coOL Buddy!
Keep your friends close and enemy CLOSER!!!
Ragnarok Online: One World, One Million Possibilities.. :)
xenkatesh is offline
- by gforz
