Old 08-11-2005, 12:04 PM   #1 (permalink)
ax3
Cool as a CUCUMBAR ! ! !
ax3's Avatar
Default ZoneAlarm 6 ! ! !
how do i clear Blocked Intrusions history ie number stated, i have 30060 intrusions ???
ax3 is offline
Old 08-11-2005, 12:11 PM   #2 (permalink)
swatkat's Avatar
Open the ZoneAlarm Control Center, click the "Alerts and Logs" button in the left pane. Next, click the "Log Viewer" tab. Here, click on the text "Clear List" which will be present in the bottom of the ZoneAlarm interface. This clears the blocked intrusions list.
To delete the log file itself, click the "Main" tab in the same section, and click "Advanced" button. Here, click the "Delete Log" button.
http://swatrant.blogspot.com/
swatkat is offline
Old 08-11-2005, 05:10 PM   #3 (permalink)
Commander in Chief
QwertyManiac's Avatar
Oh man !
30060 ?
Better surf better sites !
But actually speaking, r all intrusions that r bloked harmful ? or is it just bloating its count ?
Harsh J
www.harshj.com
QwertyManiac is offline
Old 08-11-2005, 07:28 PM   #4 (permalink)
30060 may sound huge but actually its quite normal. I have almost 100,000 in a few weeks after fresh install.
wORm is offline
Old 08-11-2005, 10:54 PM   #5 (permalink)
Let the music play.....
djmykey's Avatar
I have 19477 since 25 Nov less tho. I use Cr@pCleaner to clean all da logs.
djmykey is offline
Old 09-11-2005, 12:34 PM   #6 (permalink)
ax3
ax3's Avatar
it was a shock 4 me 2 ...
... W H O T ...
ax3 is offline
Old 09-11-2005, 05:00 PM   #7 (permalink)
ax3
ax3's Avatar
hey swatkat,
i have zonealarm 6.0.631.003 ...
things u have mentioned above rnt working 4 me ...
blocked intrusions number is still there ...
any other solution ???
... W H O T ...
ax3 is offline
Old 10-11-2005, 11:39 AM   #8 (permalink)
ax3
ax3's Avatar
hey ... no replies ...
plz ... wanna clear it ...
... W H O T ...
ax3 is offline
Old 11-11-2005, 12:02 PM   #9 (permalink)
anomit's Avatar
Hold the mouse in your right hand, move the scroll wheel up, move your eyes to the extreme right and look for swatkat. Then read the corresponding reply.
Easy, eh?
Don\'t SYN me, I'll SYN you. :p
anomit is offline
Old 12-11-2005, 04:34 PM   #10 (permalink)
ax3
ax3's Avatar
Got this ans from ZoneAlarm Customer Service ...
The "Reset To Default" button won't clear the counters under the "Blocked Intrusions" heading on the "Overview" window.
It will only clear the counters beside the pictures such as Inbound Protection, MailSafe etc.
The "Blocked Intrusions" counters only clears when you upgrade to the next version of ZA since its meant to keep track of the number of intrusions since a new version of ZA was installed.
... W H O T ...
ax3 is offline
Old 12-11-2005, 10:35 PM   #11 (permalink)
KoRn's Avatar
hey is zone alarm full version free of download wats da site,is it better dan avast(cuz avast sucks u can only send a virus to the damn chest u cant delete it cuz most viruses are found in the windows directory)i think i better go bak 2 nav from avast.
<<<*Liv3 F@sT Di3 FuN*>>>
<<H3@dB@nging My W@Y ThRoUGh LiF3>>
KoRn is offline
Old 13-11-2005, 08:40 AM   #12 (permalink)
Distinguished Member
anandk's Avatar
actually, avast is great. it has godd detection as well as deletion capabalties. it required, it even locks the virus AND deletes it at the next boot. make sure, u r using the correct settings/options.so trust me u r in good hands.
za free version, is arguabaly one of the best firewalls. za security suie has the anti-virus/anti-spy/etc in it too. it is not freeware.
visit www.zonelabs.com
> www.TheWindowsClub.com <
= www.WinVistaClub.com =
Microsoft® MVP
anandk is offline
- by gforz
