Lights on.... PCTV on..... Ghost in the Machine ??
This is something abso crazy and it is 100% true .. i encounter it everytime !
I have a Pinnacle PCTV card with a remote and its sensor (automatically start up with windows option enabled for the sensor) . Everytime i swith on the lights in my room i dont know y but PCTV starts auomatically !! What is this and Why is this
a good computer + a great gaming rig + a blasting music workstation + a recliner = LIFE !!!
guys , techies please give me some ideas on y this thing is happening !! I AM NOT JOKING OR WAS HIT ON THE HEAD B4 I POSTED THIS . This has been happening since 1 month !!! Has anything crazy and outrageuos been happening to any1 of u ??
try this
switch off all the lights. then use a torch,
This will clear whether the problem is with light or electromagnetic radiations.
If the EMR is the prob, try changing ur tube light with one from other room.
Or also do u have the tube light with electronic ballast? B'coz, electronic ballast creates high frequency electric field.
All i can say my dear friend ! that make sure no light enters your cabinet! that is for a simple cause ! there is small rather big.. or between big and small-- a chip - that chip is coated with silver colour.. make sure the colour is coated all over ! in case there is any kind of leak on coat the light is entering the chip! and that invokes the tuner card to switch on! its the same theory that the optical fibre uses - communication through light--- the best is change ur tv tuner card and for further clarification u are open to contact me! i have many mores ideas and ways to solve this kind of problem!
uh the remote sensor uses infrared technology for remote communications, maybe the light is somehow interefering with the infrared sensors of the remote receivers. just a guess..
lol
FREAKY !
~Therez a difference between knowing the path and walking the path ~
its the sensor which is picking up the signal to start . But how can normal tube lights interfere .. i mean.. these are not any special ordered lights .. just your usual lights bought from the market !!
Does anyone have a PCTv here ?? Can u check it wether .. after putting on the tube u have a auto start !
And there is not any light entering the cabinet.. pretty sure of that !
