Old 07-11-2005, 12:42 AM   #1 (permalink)
mohit sharma's Avatar
Default need a screenshot
do anyone tell me any software to take screenshot of my desktop etc. ??
if possible give url too !! lol
mohit sharma is offline
Old 07-11-2005, 12:49 AM   #2 (permalink)
Hit Print Screen then paste into Paint and select required part! Saves the trouble of using another app.
If you've Corel Draw, then Corel Capture is good. But it could be over kill. Google for some free screen capture app if you need one
LordDJ is offline
Old 07-11-2005, 01:05 AM   #3 (permalink)
where the hell is PRINT SCREEN to hit ,plz. help i need it desperately ??
" :arrow: CONNECTION BETWEEN LIFE AND TECHNOLOGY " is my topic of research !!!!
don't believe and respect any authority with closed eyes other then almighty !!!!! :idea:
Old 07-11-2005, 01:10 AM   #4 (permalink)
Karthiksn
kato's Avatar
print screen is a button next to the scroll lock and abovethe keys insert,home,page up.
If u wanna take screenshot of specific app hold alt while pressing print screen and also keep the window(of the app) open
"Walking the Path of Heaven, The Ruler of All."
kato is offline
Old 07-11-2005, 01:22 AM   #5 (permalink)
thnx @ kato , lord ,
thnx a lot !
Old 07-11-2005, 12:23 PM   #6 (permalink)
ramprasad's Avatar
I use Screen Hunter Lite...
Its really good and u can configure a hot key for it...
Proves to be useful, if u want to take many.....
Regards,
Ramprasad
ramprasad is offline
- by gforz
