Old 07-10-2004, 06:49 PM   #1 (permalink)
Rebooting
Choto Cheeta's Avatar
Default Hows the new CELARON processor
How is the new Intel Celeron Processor with compare to the AMD Athlon XP?
Keep in Mind the FSB, The cache Memory etc……
Choto Cheeta is offline
Old 07-10-2004, 09:57 PM   #2 (permalink)
celerons dont compare with amds
infact amds compare with p4's
so theres no contest
unless ur really realllyy strapped for cash ... dun even think abt celerons they are in one word ... WORTHLESS
No Mercy, No Limits.
theraven is offline
Old 07-10-2004, 10:07 PM   #3 (permalink)
gxsaurav
Posts: n/a
Raven U R wrong, he is talking about Celeron D based on Prescott core, they give performance to about old P4 cores, U know, 2.2 Ghz with 400 FSB = 2.8 GHz Celeron D with 533 FSB or close to that
Old 07-10-2004, 10:15 PM   #4 (permalink)
Agreed. After mendocino's and coppermines, celerons seemed to lose their value.
Even so ... athlon's should give more value for money, now that athlon xp's are not the flagships of AMD, with a64 out ...
Also worth checking the sempron's on really low budgets ...
Hardware - Celeron 266 MHz, 128MB RAM, Intel i740 8MB RAM
Software - Slackware Linux 10.1; Archlinux 0.7; Windows 98 SE
Humanware - GS/CS C++ L+++ w b+++ DI+ D+ e
ujjwal is offline
Old 07-10-2004, 11:38 PM   #5 (permalink)
exactly my point ...
why would u want performance of an old p4 when ur gettin an amd which compared to the performance of a new p4 ? and gives it a run for its money i might add
well anyways personal choice i dun like the celerons much .
@ujjwal semprons are just a new name to replace the older athlons and bartons and durons ..
its the same as the thoroughbred B core...
they shouldve continued the athlons under a new name i feel
for more on semprons :
http://www.thinkdigit.com/forum/viewtopic.php?t=6468
theraven is offline
Old 09-10-2004, 03:02 PM   #6 (permalink)
Rebooting
yes friends...... not every one has the money power to buy a hind processor..... but to compaire that new celaron processor with AMD batron code then keep the prise in mind its not a bad processor....... even the new cel2.4 on an ASrok mobo performing better than my AMD 2600+ XP on a ASUS mobo........ so for buget for around 25K to 28K for a full machine what processor to buy the new CEL or the AMD athlon?? cel processor is very chip.........
Old 09-10-2004, 06:54 PM   #7 (permalink)
dude if ur sure celeron performs better than ur amd .. then y are u askin ?
its "better" and "chip" according to u ... so get it if u want it !!
i however still dont recommend it !!
theraven is offline
Old 09-10-2004, 10:02 PM   #8 (permalink)
cooljeba's Avatar
celeron lacks the extra puch called the secondary cache. Very less
that's why it's cheap
..:: peace ::..
Jeba
India's answer to Imageshack
cooljeba is offline
Old 09-10-2004, 10:04 PM   #9 (permalink)
cooljeba's Avatar
btw clelron sux go for amd m8 it roxxxx
AMD me
..:: peace ::..
Jeba
cooljeba is offline
Old 09-10-2004, 10:21 PM   #10 (permalink)
darklord's Avatar
AMD RULEZZZZZZ
darklord is offline
