Try using any other browsers as your default browser.
There are 2 ways of doing this.
1. Check out the preferences/options in the new browser.
2. Select a html file. Keep the Shift Key pressed and Right click the file. You will find a new option called "Open with...". Click on that. In the new window that opens, enable "Always use this program ....". Now select the new browser from the list and click on Ok
Second way seems somewhat complicated, but works in all the cases when you want to change fille association in Windows
