Old 04-11-2005, 08:16 AM   #1 (permalink)
IG
Default RAM Speeds
MY Mobo supports DDR with a 266MHz speed (FSB??). Can I use a RAM with a higher speed like 333MHZ or so? Will the RAM work even if at a lower speed?
IG is offline
Old 04-11-2005, 08:28 AM   #2 (permalink)
IG
Mods....could you please move this to the hardware troubleshooting forum?
Posted here by mistake.
IG is offline
Old 04-11-2005, 08:36 AM   #3 (permalink)
mobilegeek's Avatar
No .. I think you cant use the higher FSB ram in motherboard.
You can put the lower freq. ram but not the higher one.
mobilegeek is offline
Old 04-11-2005, 06:55 PM   #4 (permalink)
Rebooting
Choto Cheeta's Avatar
YUP... u can use 333MHz or 400MHz DDR.... but they will work on the supported speed of the Mobo... that is, 266MHz in ur case....
rebooting
ChotoCheeta.com
Choto Cheeta is offline
Old 04-11-2005, 06:59 PM   #5 (permalink)
siriusb's Avatar
You can use a higher frequency ram module with the motherboard, no problem, as long as it is of the same type (DDR SDRAM or SDRAM). But you can use it only as a 266MHz Ram module. You can change the ram frequency in the bios to a higher value later, if ur bios supports such changes that is.
And Ram frequency and FSB are two different things dependednt on two different components as well.
http://myxp.blogspot.com
Winchester 3200+ @2,500MHz
siriusb is offline
Old 06-11-2005, 01:01 PM   #6 (permalink)
IG
Thanks Guys
IG is offline
- by gforz
