Old 02-11-2005, 04:46 PM   #1 (permalink)
Rebooting
Choto Cheeta's Avatar
Default DU Super Controler (who wants to control bandwidth)?
DU Super Controler
have any of u guyess tried this tool?? we use it in our cafe... its the only tool that i found which can run to control bandwidth usage in clint with out haveing a server... check the screen shot then u will understant what i am talking...
all other bandwidth controlling tools were server clint setup dependent... where clint share the gatway from the server... so they software is in the server to control the bandwidth share... but here it can run on the single PC to control the bandwidth distribution program wise...
Choto Cheeta is offline
Old 02-11-2005, 07:42 PM   #2 (permalink)
Just Do It
Do u mean that can be used to curb and not exceed daily usage on a single PC?
Charley is offline
Old 08-11-2005, 11:35 AM   #3 (permalink)
Hanging, since 2004..
tarey_g's Avatar
does it control bandwith usage , over client comps from server
Digit forum without nagging ads and with new features = http://www.thinkdigit.com/forum/showthread.php?p=945285
tarey_g is offline
Old 08-11-2005, 07:37 PM   #4 (permalink)
Just Do It
Where is the dude? Pls let me know abt my query.
Charley is offline
Old 08-11-2005, 11:29 PM   #5 (permalink)
have you tried netlimiter? du super controler looks like an amatuer prog, but it does do the job
srijit is offline
Old 10-11-2005, 05:57 PM   #6 (permalink)
The Hardware Labs
mohit's Avatar
@sourav_cheeta
can this prog be configured to limit the pc to use a specific amount of b/w everyday no matter which prog is using the b/w.
like i am on a 1gb limited connection and i dont want my pc to use bandwidth more than around 30 mb per day no matter which program uses it.. can this be done ??
mohit is offline
