Old 01-11-2005, 11:55 PM   #1 (permalink)
bharat_r's Avatar
Default multiple AVIs to 1 DVD
I have some avi files(DVD Rips) of 1.36 GB each.
How can I convert them into a DVD playable by my DVD player.
I have 4.7 GB blank DVDs with me.
I tried to encode using a software called DIKO but it showed that the process will take more than 24 hrs to make 2 AVIs to 1 DVD.
I had to stop it in the middle due to power failure.
Is there a easier way to convert them to DVD with custem menus & without audio lag.
Thanks
bharat_r is offline
Old 02-11-2005, 12:47 AM   #2 (permalink)
Another Brick in the Wall
drgrudge's Avatar
As for the pirated DVDs that have these 4-5 movies in a DVD, they use .dat files to burn if I not wrong.
I dont know how much time it will take to convert into .dat from .avi.
Or maybe Nero can do the job. Search the forums for more. I wont search for you.
As for the interactive menu's it can be created from a software, which you can search the forums, it has been posted some time back.
Just for info:
You will loose quality if you burn in a DVD video format. The same thing will be better if you burn in a data DVD and watch in your PC or a DVD player if it plays .avi/.mov also.
drgrudge is offline
Old 02-11-2005, 01:19 AM   #3 (permalink)
bharat_r's Avatar
ok,I searched : http://www.thinkdigit.com/forum/sear...202112&start=0
I'll try using santa DVD....
If I have any trouble I'll ask for help
bharat_r is offline
Old 02-11-2005, 11:22 PM   #4 (permalink)
Biplav's Avatar
try out divx to dvd. it can integrate subtitles.
and later u can use ur burning software to burn it to dvd(like nero and sonic)
i take me an 1 hour and 40-50mins to encode one avi movie to dvd format.
and takes another 10 mins to burn it.
"Try again, fail again, fail better" - Samuel Beckett
Biplav is offline
Old 04-11-2005, 09:21 PM   #5 (permalink)
use avijoiner
www.brizsoft.com/avijoin/
or if u want some other then follow this link:-
http://www.google.com/search?sourcei...8&q=avi+joiner
upendra_gp is offline
Old 05-11-2005, 10:40 PM   #6 (permalink)
dIgItaL_BrAt's Avatar
afaik,Nero Vision Express provides this functionality.
dIgItaL_BrAt is offline
Old 05-11-2005, 11:47 PM   #7 (permalink)
Get nero recode included with nero vision express. there are step by step wizards. U can do almost anything with the DVD video files.
remember NERO RECODE 2
rudra_chowdhury is offline
- by gforz
