Old 01-11-2005, 06:57 PM   #1 (permalink)
Generic Superhero's Avatar
Default how 2 control bandwith usage??
ohhh... for some prob or other i 4got 2 chek my bsnl usage during the whole of october
2day i see it is 2.49 gb so i am 2 pay xtra for 1.49 gb...
i wonder how it happened may be due to using google earth a lot
anyway...
plz suggest me ways how i can save on bandwith.... i use adblok xtension in ff. other than that how 2 reduce bandwid xpenditure?
i keep my IMs running all the while whether chattin or not.. do they eat up bandwith?
hence forth i ll intall s/w frm digit dvd/cds only
shud i start using opera ( i used it b4) and surf wid cached images?
Nipon
Generic Superhero is offline
Old 01-11-2005, 08:34 PM   #2 (permalink)
mera kutch nahi ho sakta
chesss's Avatar
Yup cached images is the way to go, works great for me.
Also adjust your cache settings from tools > pref > history
Also google earth is a total bandwidth killer - i used 1.3gb in 3 days
I am not sure how much bandwidth IM's take, though i expcet they will be constantly pinging.
Try using a data-transfer monitor or something next time.
chesss is offline
Old 01-11-2005, 09:06 PM   #3 (permalink)
Default Please help me
thanx chess for ur reply
i am completely at a loss... when i saw the usage stats this evening on bsnl site my jaw fell!!
so now i know that it is only coz of google earth... i used it quite a lot----all those hi-res img-s must hav spent my bandwith
i request every1 to gimme more suggestions on how i can reduce bandwith usage
Nipon
Old 01-11-2005, 10:27 PM   #4 (permalink)
Version 2.0
Deep's Avatar
Use onspeed try it for 7 days and see the effect..
I have tried it on my triband connection and it saves lot of bandwidth and loads pages much faster...
So if you like it then you can purchase it for Rs. 2100 a year
or you can even try google's web accelerator, I think it also works on same funda i.e. generating pages from cache...
Ragards,
Deep
- Deep Ganatra -
www.whoisdeep.com
www.twitter.com/DeepXP/
Deep is offline
Old 02-11-2005, 05:02 AM   #5 (permalink)
Just Do It
Charley's Avatar
What abt watching or broadcasting live cams , does it hog ?
Charley is offline
Old 02-11-2005, 05:19 AM   #6 (permalink)
18 Till I Die............
Yeah It does. All kind of multimedia take up more bandwidth. Though most are low resolution they don't take up such a big bandwidth but it sure does take a big chunk of bandwidth.
mehulved is offline
Old 02-11-2005, 06:53 AM   #7 (permalink)
Just Do It
Charley's Avatar
When i watch yahoo cams the bandwidth is little ... I have to try wit the other cam sites to verify it.
Charley is offline
Old 02-11-2005, 07:24 AM   #8 (permalink)
I've faced this problem before and I tried my best to control it. Here are a few tips from me
1) Get some browser other than IE which offers you high control over what all you can block from the internet
2) Block Pop-UP Ads
3) Block Google Ads
4) Disable Images for your General Browsing and Enable them only for a few websites which you think are terribly important.
5) Keep a Track of what you download. Have an account of the major downloads you've made
6) Since you have 1 GB/month, divide it by 30, you get 33. Make sure your daily consumption is around 33 MB.
7) Continuosly check your BW usage, perhaps if you feel in the middle of the month that it has gone high and you find it;s 800 MB already, then reduce your usage for the rest of the month.
8) Important - Disable Flash Images 1000%, they use Bandwidth LIKE HEck.
9) Reduce Google Earth - If it is your buisness, okay but for a hobby if you wanna check out all kindsa places then get a better broadband
10) Use Google WebAccellarator or some tool which loads cached pages. Onspeed is paid BTW.
Don't think your cutting all in Life. Try this for a week and see how much you are using. If you feel, you can use more, then change. I'm talking about this in experience only. Once Upon a Time I had Iqara Connection and I successfully used 500 MB for 4 full month.
Hope this Helps you
Regards
Retro
Retro is offline
Old 02-11-2005, 12:52 PM   #9 (permalink)
busyanuj's Avatar
you can configure the Windows' hosts file to block ads. read more here
next, you can also use software such as DU Meter to monitor your daily internet bandwidth usage. It will allow you to use your bandwidth more efficiently.
busyanuj is offline
Old 02-11-2005, 04:36 PM   #10 (permalink)
i installed fasterfox--an xtension of ff
shud i use this simulataneously with google web accelerator or any one of them??
in either fasterox or google web accelerator, i hav set the options to not prefetch any page assumin that it's a waste of bandwith. am i right?
like we get in opera, any way 2 use cached images in ff? or ll google web accelerator take care of that
Nipon
Old 02-11-2005, 04:46 PM   #11 (permalink)
Rebooting
Choto Cheeta's Avatar
check this tool out.... may help u...
rebooting
ChotoCheeta.com
Choto Cheeta is offline
Old 02-11-2005, 08:30 PM   #12 (permalink)
selva1966's Avatar
But during test phase it works only in North America and Europe.
selva1966 is offline
- by gforz
