My system has a peculiar problem.
In WIN98 all keys function fine. In WinXP (& also on DOS prompt of WInXP) the following keys give wrong text as shown below.
(i) Shift + ` = ¬ Should be ~
(ii) Shift + 2 = " Should be @
(iii) Shift + 3= £ Should be #
(iV) Shift + ' = @ Should be “
(v) \ = # Should be \
(vi) Shift + \= ~ Should be |
(vii) My 'Right Alt' key doesnot work when I press 'Alt+ Enter' or 'Alt+F'.
But it works without fail when I Press ' Ctrl+Alt+Del '.
I am sure it is not a keyboard problem since the keyboard works absolutely fine without producing any wrong text in WIn98.
And also I have checked by interchanging with several new keyboards.
Please suggest solution. [Don't suggest to re-install WinXP.]
Thank You.
