heya
you could use corel photopaint for that just chooses 24-bit rgb format and check the creat movie box and set ur frames you could also alter no of frames later.
and unleash the creativity.
I dont think irfan view could do this and if it can you need to register it first and prchase regestration code.
(but i haven experimented that much with it.)
all u got is either 0 or 1 there is no place for 1/2 same is also true for life.
