Old 30-10-2005, 10:34 PM   #1 (permalink)
mario_pant's Avatar
Default i need a review on NOD32...
guys..
i am thinking seriously of switching from NAV2006 to NOD32...
plz tell me if this is a nice choice...
and plz tell me the plus points and negative points....
query 2: also please tell me if McAfee AntiVirus is a resource hog or not, so maybe i can make up my mind to buy that.....
mario_pant is offline
Old 31-10-2005, 01:08 AM   #2 (permalink)
swatkat's Avatar
Hmm....These links can help you:-
http://www.av-comparatives.org/
http://www.pcmag.com/article2/0,4149,978452,00.asp
http://www.ciao.co.uk/NOD32__Review_5420558
http://swatrant.blogspot.com/
swatkat is offline
Old 31-10-2005, 01:56 AM   #3 (permalink)
In simple words - NOD32 is the BEST Anti-virus, certainly better than Norton and McAfee.
Hexus is offline
Old 31-10-2005, 05:03 AM   #4 (permalink)
I wont say NOD32 is the best. No AntiVirus is the best.
As far as NOD32 goes, it has excellent detection, the BEST heuristics in the business, a good-looking but slightly complex interface. It has daily updates, but not so much on Saturdays and Sundays.
Last edited by Happy Bytes: Today, at 3:45 AM. Reason: added a signature spreading worm....
AcceleratorX is offline
Old 31-10-2005, 05:04 AM   #5 (permalink)
BTW, McAfee VirusScan 9.0 is somewhat resource-heavy, but not much on my PC.
Old 31-10-2005, 12:47 PM   #6 (permalink)
NOD32 is a good choice, but since you mentioned resource usage I suggest you download a trial of FPROT before deciding. It always gets a 100% in AVBulletin tests and on a good day it won't use more than 2 megs of RAM (6 megs max).
Keith
Keith Sebastian is offline
Old 01-11-2005, 01:15 AM   #7 (permalink)
And also, a single personal license of F-Prot allows you to use it on five computers!
