Old 06-10-2004, 11:49 PM   #1 (permalink)
navneeth_snr's Avatar
Default Problem with Burning
Hi,
I have an video file of 86 min, and I want it to get copy (burn) to my cd. But it doesnt fit in 700 mb. Any solution. And the video file which I copied is from my friends cd. even cd to cd copy does not working
Navaneeth
My Phones: Motorola T180, Nokia 2600, SE J300i, SE W810i
navneeth_snr is offline
Old 06-10-2004, 11:53 PM   #2 (permalink)
Version 2.0
Deep's Avatar
overburn ? try that option in nero...
File (or edit) - Pref - exper features..
enable overburn..
while burting cd select Track at once (not disc as once...i)
google before burning it..
Deep
- Deep Ganatra -
www.whoisdeep.com
www.twitter.com/DeepXP/
Deep is offline
Old 06-10-2004, 11:59 PM   #3 (permalink)
U can try overburn, bur also try Alcohol120%, CloneCD or Blindwrite. theyll copy sector by sector. so that was its would be a exact replica of ur friends CD but u need to have ur friends CD to to copy na.
Get an 800mb disk(about Rs. 15) and try overburn if it fails on a 700mb disk.
sniper is offline
Old 07-10-2004, 12:06 AM   #4 (permalink)
good idea sniper, I will try to get the 800 mb disk. does it support samsung 40x-12x-40x burner?
Navaneeth
Old 07-10-2004, 12:09 AM   #5 (permalink)
Also I use nero 6.3, does 800 mb supports
Navaneeth
Old 07-10-2004, 02:22 AM   #6 (permalink)
Man i just tried 800mb disks today. it burned fine with an LG52x. haven't tried burning on my SONY crx230e. I can tell u for sure that Liteon DVD RW does not burn nor recognize it. I HAD BURNED USING ALCOHOL after enabling overburn. I HAVE NOT tried with nero 6.3125.
Sony was reading the disk(about 750mb data) before but not now . neither of the two disks . Well. I hope i didnt loose my Longhorn.
another thing, Nero will not recognize that disk as 800mb, it showed me as 702 but ull be able to burn it after enabling overburn to exactly 90 minutes. i think the funda here is that on that disk the tracks are already conpressed. when u set overburn to 90 mins not more not less the software will record exactly on the tracks of ur disk, cos thats how its made. so that mean. keep overburn setting to 90 minutes even if ur data size is 705mb or 775mb.
Also get a firmware upgrade for ur drive. Google it. THATS VERY IMPORTANT.
sniper is offline
Old 07-10-2004, 02:59 AM   #7 (permalink)
learn how to overburn
http://www.thinkdigit.com/forum/viewtopic.php?t=5346
learn a few safety tips and why u shouldnt overburn
http://www.thinkdigit.com/forum/viewtopic.php?t=3792
No Mercy, No Limits.
theraven is offline
Old 07-10-2004, 09:22 AM   #8 (permalink)
ok, I will try ALCOHOL buring software!
Navaneeth
Old 07-10-2004, 09:33 AM   #9 (permalink)
thanks Raven
sniper is offline
Old 07-10-2004, 12:46 PM   #10 (permalink)
where can i get 800 mb disk for 15 bucks.. me from mumbai.. here it cost 25-30
Attack life, it\'s going to kill you anyway.
walking-techie is offline
Old 07-10-2004, 05:54 PM   #11 (permalink)
To divx
Hmm
amitsaudy is offline
Old 07-10-2004, 09:43 PM   #12 (permalink)
hmm, good idea Indyan! But I brought two 800MB cds (for Rs 17/- each) and solved my problem.
Navaneeth
Old 12-10-2004, 12:35 PM   #13 (permalink)
Which brand?
What speed do they support?
Old 12-10-2004, 01:33 PM   #14 (permalink)
i got Amkette 52x 800mb rs 15
sniper is offline
- by gforz
