Old 30-10-2005, 07:20 PM   #1 (permalink)
SNIST Screamer !!
vijay_7287's Avatar
Default System temparature Query ???
well we have always dicussed about system temparatures and over heatin stuff ...
i think now its time to these as stats ...
wat is the max CPU core temp at which it can run for 3 hrs on the trot ???
and the same for m/b?
wat r the ideal startup temparatures???
evrybody put temps here???
i hav startup temparatures of 48 degrees and 35 degrees
and i think max should can be upto 58 degrees and 45 degrees
so wats ur take ???
vijay_7287 is offline
Old 30-10-2005, 11:33 PM   #2 (permalink)
cpu and motherboard temperatures depends on which CPU/ which core/ and what speed ur runnin at
there is no standard for the temperatures
No Mercy, No Limits.
theraven is offline
Old 03-11-2005, 05:49 PM   #3 (permalink)
SNIST Screamer !!
vijay_7287's Avatar
common dude i know that ..
i wanted people to post their temps so that it would easy for others ..
any way can anyone tell me are my readings optimal for a
intel p4 3.00ghz on an intel original 865gvhz(micro atx ) m/b ???
Old 03-11-2005, 05:59 PM   #4 (permalink)
The Hardware Labs
mohit's Avatar
for intel prescott the cpu temp should be around 55-60 C and the mobo temp should be around 40-45 C.
mohit is offline
- by gforz
