Old 30-10-2005, 01:21 AM   #1 (permalink)
hafees's Avatar
Default How to enable GPRS ? is PCI Bluetooth card available?
Hi ! I m living in Kerala and having an airtel prepaid connection. Recently i bought a SE z520i. how to enable GPRS for that?
Also is there any PCI Card available for PCI to Bluetooth. or USB to bluetooth?
hafees is offline
Old 30-10-2005, 02:21 AM   #2 (permalink)
The Hardware Labs
mohit's Avatar
To enable GPRS goto the nearest airtel connect and they will do it for u . and u can buy a usb bluetooth dongle with a range of 10 metres or more and use it to connect your pc n phone. there are many many brands of these dongles available but i suggest going for some decent one like Belkin. Those chinese brands suck big time.
mohit is offline
Old 30-10-2005, 03:17 AM   #3 (permalink)
144
144's Avatar
You can get a decent Bluetooth USB dongle with 100m range for approx Rs 700 - 600.
On a long enough timeline, the survival rate for everyone drops to zero
144 is offline
Old 30-10-2005, 06:21 AM   #4 (permalink)
mobilegeek's Avatar
Even the one with 10mtr range is good enough .. it costs around 500 bucks
mobilegeek is offline
Old 30-10-2005, 10:01 AM   #5 (permalink)
Dial 121 for customer care from you Airtel mobile and tell them to activate this for you and also for Mobile office gprs OTA setiings. After you recieve OTA message. open message, go to options and select save to save the satteings. For blutooth, I recommend to you to go for belkin 100m bluetooth dongle. If you are using xp sp2 then dont install the cd which come with dongle. Just connect and start using.
vishalbhatia is offline
Old 30-10-2005, 06:37 PM   #6 (permalink)
choudang's Avatar
Send MO to 646 or 501. you will receive one setting, save and activate the setting.
do you subsc the GPRS conn?if not, do it
For every action, there is an equal and opposite criticism.
choudang is offline
Old 31-10-2005, 01:28 AM   #7 (permalink)
hafees's Avatar
how much is the rent for gprs service. i m in kerala.
Also, after gprs activation, is it possible to browse the net thru my pc using the mobile with bluetooth dongle( i.e without purchasing any usb cable to connect my cell)
hafees is offline
Old 31-10-2005, 03:42 AM   #8 (permalink)
mobilegeek's Avatar
best thing is to check at the local authorised Outlet
and
here in delhi the rate is Rs.499 pm for unlimited data transfer (AirTel)
Yes, It is very much possible through BT
most of the phones have inbuilt modem
- by gforz
