Old 18-05-2004, 11:22 AM   #1 (permalink)
club_pranay's Avatar
Default Hanging BIOS
i have ,KOBIAN-Mercury 865GVM-L, P4 2.80 GHz, 512 MB DDR, 80gb 7200 rpm hdd, 52X CDROM, 1.44 floppy, 14 inch color monitor. till now i have not installed any add-on cards, my problem is whenever i try to go to BIOS SETUP, IT HANGS. when i hit "DEL" it hangs anywhere leaving with no option other than to reboot. i have tried changing the battries and resetting the BIOS but notthing works. in short, i have to spend around an hour or two just to change the boot sequence!!! is this a problem with motherboard? or just flashing the BIOS will do?? please help!!!
Be not Thou far from me o Lord....o my strength....haste Thee to help me.
club_pranay is offline
Old 18-05-2004, 12:04 PM   #2 (permalink)
Your RAM may also be at fault.
wORm is offline
Old 19-05-2004, 10:51 AM   #3 (permalink)
I must include that if i dont disturb the bios, the computert works great! awsome speed
Old 14-09-2004, 12:09 PM   #4 (permalink)
Default Thanx
the problem is solved . Actualy the processor was at fault...
- by gforz
