Old 30-10-2005, 12:22 AM   #1 (permalink)
yrana2002's Avatar
Default BAD RAM
Hello! I've got a serious problem. I've got 2 256MB DDR RAM cards installed. One IBM & one hyp... After running for a while, the comp hangs up & sounds of swtiching off comes from inside the cabinet. Recently, a Blue screen giving fatal error came to view showing dumping physical memory. What's happening? I tried to remove one of the RAM to clean it but now i cannot fix it as both the notches aren't getting locked by me atleast.
Savvy!
yrana2002 is offline
Old 30-10-2005, 02:16 AM   #2 (permalink)
The Hardware Labs
mohit's Avatar
if u have never fiddled with your cabinet open then please call your computer dealer for help , u will end up screwing the machine if u keep trying to do things yourself.
mohit is offline
Old 30-10-2005, 03:32 AM   #3 (permalink)
144
144's Avatar
Are you talking about 2 RAM modules of the same frequency ( eg: 400MHz, 333MHz, 266MHz ) or different frequency.
The 'sounds of switching off', do you mean that the system speaker gives some beeping.
The Blue Screen that you have seen must be the Blue Screen Of Death ( aka: BSOD, google for BSOD or search this forum for BSOD ).
It would be better if you can give more info:
Like what is the Operating System you are using?
Give a full system Spec as far as your knowledge?
Please note the error code on the BSOD, it should be something like this:
0x0000004e (0x00000099, 0x00000000, 0x00000000, 0x00000000)
Try 'memtest' and see if you can find fault with it.get memtest at:
www.memtest86.com/
Also since you have removed your modules, try with one at a time and see if the problem reccurs.
If it does not you might still confirm your findings with memtest
Physically cleaning your modules might not be the solution to your problem.
Anyway, the problem your are facing while fixing the module,might be a smiple error in the technique.
Make sure that, the module is placed facing the correct direction, i.e. see the notches on the SLOT and the MODULE -- make sure they are matching and just press in the middle slowly. DO not force it. (please do everything with the POWER OFF )
It should 'click' into position quite naturally. If NOT, you are doing something wrong. Get expert help *( vendor )
On a long enough timeline, the survival rate for everyone drops to zero
144 is offline
- by gforz
