first of all please dont tell me to search the forum....if ur going to please tell met he correct terms...cos whenever i try i end up getting all the results i dont want
well i tried to do a quick convert from ntfs-> fat 32 and lost all the data on that drive.is there any tool to recover the data.
i want to install rh 9 on d: which is extended partition.can i convert it to primary without formatting? the rest of my partitions are in this extended partition.
pls reply ppl
http://xforum.hugetop.com
Tutorials, Whitepapers, Beginner articles, How tos and Getting started Tutorials. All information you need about Computers, Ethical Hacking, Security, Web, Web Programming.
Yup guss after changing FS it's realy tuff to get data back any way try easy recovery pro. might work for u ,
or if u have norton rescue than can go for that.
Music is like Sex, The more you get, the more you want.
