Old 29-10-2005, 01:12 AM   #1 (permalink)
Default Why can't i play the DVD.
I recently brought a dual layer DVD 9 format Harry Potter DVD with 3+1 movies, although my LITE-ON DVD ROM JLMS XJHD 166S plays all DVDs , but can't play this one. Digit has always referred this and now i face this.All SONY drives play this.What to do ???
rudra_chowdhury is offline
Old 29-10-2005, 01:28 AM   #2 (permalink)
bang bang!
Chirag's Avatar
Does ur dvd rom supports dual layer?If yes then their might me a dvd problem.
Chirag is offline
Old 29-10-2005, 01:28 AM   #3 (permalink)
whats this and whats that ?
what are u talkin abt ?
what exactly is the error that u get ?
try makin an image of the disc using ultraISO
then mount it on a virtual drive and try n play it
No Mercy, No Limits.
theraven is offline
Old 31-10-2005, 03:07 AM   #4 (permalink)
According to the Nero info tool this Lite-on 16X DVD ROM can read all typeas of single layered DVDs, DVD+R DL but not DVD-R DL. The DVD movie was the latter one.
All I want to know
is it always this way or my drive has gone faulty.(People with Lite-on DVD drives please reply)
why should digit always refer to Lite-on over Sony for DVD Drives without adequate tasting. We got the habit of depending on Digit, But not any more, after this !!!!!!!!!!!!
Old 31-10-2005, 11:45 PM   #5 (permalink)
bharat_r's Avatar
Is the DVD being detected by the drive? Or u just can't play it in any DVD playing app?
bharat_r is offline
Old 01-11-2005, 12:42 AM   #6 (permalink)
no it depends on the firmware of ur drive
if u want u can try upgrading ur firmware but it is very risky and if done wrong it can make ur drive useless
theraven is offline
Old 04-11-2005, 02:41 PM   #7 (permalink)
i have upgraded to the latest firmware.But the drive can't even detect the DVD. Although a neighbourhood SONY DVD ROM can play it fine
Old 04-11-2005, 03:51 PM   #8 (permalink)
the firmware SHOULD have support for that format
did u check that with dvd info ?
theraven is offline
Old 05-11-2005, 11:58 PM   #9 (permalink)
i used nero info tool to check which format(s) i t supports and which are not suppported. Now according to the Nero info tool this Lite-on 16X DVD ROM can read all types of single layered DVDs, DVD+R DL but not DVD-R DL.
The DVD movie was the latter one. As in the disc type nero showed it as dual layered, but as it was not read by the ROM it must have been, DVD-R DL.
The bottomline the Lite-on Drive doesnot support DVD-R DL , SONY drive does. And Digit still insists on lite-on above SONY.The question is WHY ??????????????????????????????????
Old 06-11-2005, 03:19 PM   #10 (permalink)
i dunno ask digit
we are members we dun have collaboration with digit
im sorry i thought u needed help
if u wanna crib abt digit's test centre join the million others or write into their head office
locking this thread
pm me if this needs to be reopened
theraven is offline
- by gforz
