Old 29-10-2005, 12:28 AM   #1 (permalink)
Microsoft MVP
Vishal Gupta's Avatar
Default S/w to check the exact amount of RAM in the system?
Guys!
Is there ne s/w available on net to check the exact amount of RAM in the system?
I mean I hv heard that there r many RAM available which shows amount like 128, 256 etc in My computer properties but actually they r not of that capacities and hv only 64 or near about it. (these RAms r locally assembled and not original)
So can ne1 suggest ne s/w which can show the exact amount ot RAM?
:arrow: http://www.AskVG.com/
Vishal Gupta is offline
Old 29-10-2005, 03:56 AM   #2 (permalink)
siriusb's Avatar
I've never come accross such anamolies. But you can always check with cpuz.
http://myxp.blogspot.com
Winchester 3200+ @2,500MHz
siriusb is offline
Old 29-10-2005, 12:06 PM   #3 (permalink)
Core i7 (nehalem) Owner
ashu888ashu888's Avatar
There is CPU Z available for tat purpose..U can down load this from here....
http://www.freedownloadscenter.com/U...ies/Cpu_Z.html
Cheers n e-peace..
Core i7-920
MSi X58 Pro-E
Corsair 3x1GB
Tagan BZ1100
WD 1TB
22" Samsung 2233SW
APC SUA1500i UPS
ashu888ashu888 is offline
Old 29-10-2005, 08:04 PM   #4 (permalink)
Even i have not come across such a issue. The best way would be to use cpu-z.
Regards....
shivaranjan.b is offline
Old 29-10-2005, 08:28 PM   #5 (permalink)
Microsoft MVP
The link for CPU-z is not working...
Can't d/l from the link, pls check it.
And how can it make sure that the amount its displaying is correct and real?
s/w like Everest, etc also shows amount of RAM installed in system, do they show correct?
Old 29-10-2005, 08:41 PM   #6 (permalink)
Walking, since 2004.
mail2and's Avatar
Everest is perfect.. if it shows that there is 256 mb ram then there is 256 mb ram...
Mumbai, I miss you. :(
mail2and is offline
Old 29-10-2005, 08:52 PM   #7 (permalink)
Microsoft MVP
thnx buddy!
I hv this s/w and its showing exact 256 MB RAM installed in the system...
- by gforz
