Originally Posted by go4inet
you need to learn php programming, so that its simple for accesing .htapsswords
i dont think is has got anything to do with PHP dude..
its completely difference concept..
anyways getting back to the topic..
i dont think .htaccess thing work with IIS..it works with Apache only..
so to make directory protection in IIS u need to select security tab in IIS control panel under desired directory and change settings there...
but for all these u need admin access and i doubt anyone will give u access in shared hosting (i am not sure whether control panels will have that option or not..check with your web host)
regards
Deep
P.S. btw check this page
http://www.htmlite.com/HTA006.php for htaccess code format and sample...or check the link provided by
firewall
