Help needed on writer and for samsung 52 X media
I am using HP writer it has maximum speed 4X for cdr and rw
I am getting this error while writing to blank cds of samsung 52 X only :-
D0100: I/O error (03/02/00) - CD recorder error - cannot seek to the requested location
when i click for help i got this from help file of easy cd creator to see more about error:-
Reason for receiving this message:
The CD recorder wasn't able to find a requested location on the CD-R disc.
What to do:
· Check for faulty or disconnected cables between your computer and your CD recorder.
· Check for improper termination of the bus (SCSI only).
· See the documentation provided with your CD recorder or contact the manufacturer of the
drive.
I am getting this error while writing to samsung 52 X CDR media only
I also wrote to samsung 16 x and
I also wrote to sony 48 X and
I also wrote to imation 16 x
without any problems after losing 2 cds of samsung 52 X so to see whether problem is with media
or drive. wrote that same data
Actually i wrote to 3 samsung 52 X CDR and got successful only, for 1 cdr, but that also shows
this error after easy cd creator finished writing :-
But i can read this cd in other cd rom drive and also copied all 770 MB data to check.
all files copied successfully
actually when i click create cd then writer pauses 10 seconds to get buffer and then writes to cd
so buffer level will be 100 % before strarting writing
this is normal because that 10 seconds hard disk is busy so to provide data to the writer.
But when i use 52 X samsung media
the writer pauses 30 seconds to get buffer and then writes to cd
for all the 3 cds of samsung 52 X
also when writing TOC the time shown is 1:02 minutes remaining and it takes actually that much
time as shown
but for 52 X samsung the time shown is 1:02 minutes remaining but it took 5 to 7 second to write
TOC i saw that
i am writing at 4 x and only 699 to 700 MB data maximum and using easy cd creator
and i am using this writer for 3 years never got error before
please help.
but if u say because u are writing to 52 X so getting error, then i wrote successful
to 48 X media of imation.
Please please give suggestions and also tell what to do with that remaining media
i purchased 10 blank cds so got 7
