Old 17-05-2004, 04:42 PM   #1 (permalink)
Default Linspire and Lindows
Hi I have Lindows 4.0 installed on my system and I also have Linspire
4.5.397 on CD I want both Linspire and Lindows to be installed on my
system as dual boot configuration
I also know that they are of both same make and build but differ only in names and build versions I want them to be installed on my system as dual boot configuration with Lindows 4.0 being the default OS
Let me know how do I configure the boot loader in Lindows 4.0 and Linspire 4.5 .Is there a way out I can make out this please quote to me at nikhiltheprince@hotmail.com
Hi
nikhiltheprince is offline
Old 18-05-2004, 01:20 AM   #2 (permalink)
Certified Nutz
sreevirus's Avatar
doubts clearing later... where did u get the damn thing? linspire is the best desktop linux there is for novices. Pls tell me where did u get linspire. If u bought it how much did it cost?
"Don't take life too seriously. You'll never get out alive!" - Bugs Bunny
sreevirus is offline
Old 18-05-2004, 08:00 PM   #3 (permalink)
Any one not like Sreevirus? Please
Hi
Old 18-05-2004, 09:31 PM   #4 (permalink)
Certified Nutz
sreevirus's Avatar
man, i just asked a question, dont get heated up dude. I'm new to linux and wanted lindows/linspire. Heard its much better than other flavours.
Anyway post ur question on www.linuxsolved.com forum. they'll definitely have an answer.
Or look out for ricky, he usually solves the linux problems in this forum.
Old 18-05-2004, 09:37 PM   #5 (permalink)
YA... LINUX SOLVED IS THE BEST ONE MATE ! GO THERE !
Vande Mataram - Two words that became a Fiery War Cry and Electrified the nation towards Freedom. A mantra that instills a sense of Pride and belonging.
go4inet is offline
Old 21-05-2004, 08:47 AM   #6 (permalink)
No Sree Not that its Licensed ,but what to do even am an Linux hard core fan had been into it foe quiet 2 years now .Now even Lindows confuses me with its licensing policy actually Its something like Windows License for Linux.Ok Do you want to have it and if u can download that hectic one CD download then update here ur quotes so that I can personally send u link.
Hi
Old 22-05-2004, 02:26 AM   #7 (permalink)
Walking, since 2004.
mail2and's Avatar
well i have a question: can linspire be used with windows fat32 partitions.... Like while installing cAN we use fat32 part. instead of the dumb swap et al
Mumbai, I miss you. :(
mail2and is offline
Old 14-08-2004, 07:09 AM   #8 (permalink)
Well I have dun it last week, at last
Dual booted Linspire OEM with Linspire Developer Edition...
Yipppeeee
My mentor was surprised and impressed too.
Thats why I Love LinuX!! I Live LinuX!!
Thanks All,
For caring it.
Hi
Old 14-08-2004, 06:34 PM   #9 (permalink)
Well I dont have answer for your question nikhiltheprince. But I havent used linspire or lindows yet. But if it is same as the other linux distributions (lilo & grub works) then I assume that you use lilo then goto /etc/lilo then try to find out the place where the boot image is installed it should be something like
/disks/mylinuxdistribution/boot/vmlinuz
then add these line
image=/disks/mylinuxdistribution/boot/vmlinuz
label=mylinux (nospaces)
root=/dev/hdc9( the root of that distribution)
then take terminal and run lilo.
You should success. Then reboot you must see the new one.
NOT Logged out for ever (well certainly) ;)
BONZI is offline
Old 14-08-2004, 06:35 PM   #10 (permalink)
Ok if you are looking for a linux distribution for a n00b than try Xandros(open circulation edition) its good and free now
BONZI is offline
- by gforz
